BAYLINER185
- Joined
- Jul 30, 2007
- 474
Ok, I have a cruser that was outfitted with 4 marine batteries. 2 per bank in parrellel so that eack bank has about 1200 amps of power. This I beleive was done by the previous owner and Ive been thinking about this set up and may modify this.
Bank one is supposed to be a starting bank and bank 2 is for everything else. Im thinkng I DONT need 2 battereis in parellel for starting and maby I can take the extra battey and make my bank 2 a tripple battery set up.( 1800 amps more or less ) Im not sure that is really possible as I dont think there is room for 3 batteries on that side of the boat.
The boat does have a stove fridge and power inverter for getting 120V when away from shore. I plan on adding a 27" LCD TV w/ DVD player and wiring it into the 120 volt outlet that is real clsoe to where the TV is going.
What would be better do you think? 1 battery for starting, 2 batteries in parallel for the BANK 2 stuff and the 3rd for the inverter? The inverter is 3000 watts and Im not even sure it would turn on with just one battery connected. Now that I think about it I dotn think it will?
OR
should I just put an isolator between the dual battery banks. It has a perko switch that switches BAT 1 / ALL / BAT 2 and technacally an isolator can take the place of that. I know I can do an isolator and the switch and if I do, do an isolator I will want to leave the switch becuase I dont want to see the hole that will be left where the wiring comes through to the back of the switch if the unit is removed. The inverter right now is conneced to bank 2 directly and I havent used it at all except to run a small vacume for about 5 minutes.
Just looking for other thoughts. My machanic thinks I have the small stock altnator and suggested going up in size. I think thats a good idea and will wind up doing that as soon as I veryfy what I have installed now on the motor.
I havent had ANY power issues whatsoever so thats not why Im posting this. I just want to ensure no problems and possibly do it better if there is a better way.
OR
