Battery Cables Outer Heat Shrink/Wrap
thull
What's the long (6-foot) outer heat shrink/wrap stuff called for small outboard batter cables? This is the outer layer that the positive and negative cables are sleeved inside of it together. Where can I find it? This is for a 1980s 25hp Evinrude with electric start. Thanks.
dingbat
It's not wrapped.....it's called duplex battery cable.
Should be able to get it at just about anywhere that carries cabling
tomhath
You might also be thinking about split loom tubing (sometimes called split flex tubing). Any hardware or auto parts store carries it.
