Battery cables
dcata
Got a 93 115hp Johnson that I need to replace the battery cables from the engine to the battery and was wondering if anyone could help me with figuring what size cables I need. I called a marine store and they was asking what amps are drawn from my alternator and questions like that. I looked at the old cables and couldnt find any info. Any help will be highly appreciated.
rockyrude
Re: Battery cables
I would suggest at least 6 gauge wire 4 would be better. I saved some money by going to my local auto parts and bought a set of decent jumper cables and put new ends on them, cost less than $20.
samo_ott
Re: Battery cables
Hey, that's a clever idea. Jumpers go on sale cheap a lot. Thanks!
k4ubr
Re: Battery cables
how fare is the battery from the motor. this is the most important ? 4 gauge should be used . up to 10 feet
bankerjohn
Re: Battery cables
If your going to be running your boat around salt water, I'd recommend against the typical jumper cable route ... in favor of ABYC approved tinned copper Type III cable like Ancor sells. Considerably more expensive, but it will hold up against corrosion a lot better!
