I've read through a number of threads on battery chargers here and understand some of the basic issues involved. But I'd like to quickly describe my situation to see if it results in any specific thoughts.
I just repowered my 21' center console with a 2011 Mercury OptiMax 250 outboard. On the advice of the manual and the installer, I replaced my old deep-cycle batteries with a pair of cranking batteries (Interstate 24M-XHD, delivering 800 CCA, 1000 MCA).
I keep the boat in a slip, and bringing the batteries home to charge isn't an attractive option.
The marina tells me I'll need a true shore-power cable if I want to run a charger on the boat from dock power. The boat doesn't have a receptacle or any 110v wiring on it. This approach in theory would be feasible, but I gather I'd have to cut into the boat's console to install a receptacle, which I'm not keen to do. I'd like to put a new fitting on the end of a shore-power cable so I could squeeze it through one of the ventilation holes of my boat's console, but I gather that would make it non-code.
Solar seems like an interesting option. I've read posts here that indicate that boat batteries are hard to charge off reasonable-sized solar panels. (I'd want something small enough to stow in a dock box.) But when I've had the batteries at home, I've gotten decent charges from a plug-in system that puts out 1.25 amps per battery at 12 volts.
For this situation, does solar sound feasible?
