I have a question related to the setup of my onboard charger and also a question related to the starting battery.
1. The onboard charger question is related to a minn kota mk315D charger that I purchased new about 2 years ago and setting it up in a 24v setup. I have one set of cables going from the charger to a Die Hard Platinum 850 CCA battery, another set going to one battery setup in a 24v setup and the other set of cables going to the other battery in the 24v setup. I am wondering if there is an issue with this ?
2. I also have a question related to the Die Hard battery. I use this battery for starting the motor (120 hp) and it has already seemed to have gone bad. I charged the battery for about 6 hours the other day. When I stopped charging it, the meter showed that it was about 50%. I came back down 2 days later and it was now showing 10%. I don't know if this battery is already dead or if there is some other way to confirm before taking it back to get it replaced. I did try to crank the motor and it would barely crank the motor a few times.
Any help would be appreciated.
Thanks.
Thanks.
