I have a 20` proline sport with a DF150 Suzuki.
I found my battery dead for some reason. I had left the battery switch on but could not find any accessories on. I took it out and put a 10 amp charge on it in the garage for a few hours and dropped it to a 2 amp charge overnight.
After reinstalling the battery, I forgot which terminal the yellow wire hooks to. edit...this wire feeds the dash gauges and controls. Can anyone help? I tried the positive post but I got an alarm and check engine light flashed and sounded once in about every 10 seconds. I put it on the negative and everything works fine but I noticed the volt meter on the dash read 14.5 volts after starting te engine and taking the throttle up to about 1000 rpms it was just below 15 volts. I checked the voltage with a DVM. Is this normal or did I screw something up?
