Battery connection
Sc25175
Rookie question. Where on the out board do I mount the positive and negative wires from the battery. I am assuming the positive goes to the starter motor but not sure on the negative
Sc25175
I have a 2008 etec 175 and am trying to figure out how to connect the positive and negative cables to the engine?
Tell the whole story.-----Did you just buy this motor ?----Make sure you get this right.----Mistakes might be expensive.
mike_i
Ensign
The positive cable goes thru an ignition switch maybe a battery switch and other stuff before it hits the starter. We need more details on what you're doing.
GA_Boater
The positive goes from the battery to the solenoid, possibly through a battery switch.
Details are in the manual.
Crosbyman
from the manual...which you should get at this point. If you plan servicing your engine you should get the EV diagnostic software
visit the ETEC user group...good search utility and ETEC experts to answer your questions
