Re: battery dead after 10 days
Its really pretty easy to find the problem. Get our your meter, set it to amps x 10 or so and then disconnect the positive lead to your battery. Put your meter inbetween the positve battery cable and the battery terminal. You should get some reading. That is your leakage. Now, with the meter still connected go up to your fuse box and start removing the fuses one at a time. When the needle on the meter drops to zero as you pull out a fuse you have found your problem. Whatever that fuse goes to is the problem. Just check the wires for breakes or corrosion and then the device to see if it has become defective. You can almost always find those slow electrical leaks this way.<br /><br />Thom
