Battery draining
Bonker43
Hello Fellow Boaters,
I have a Trophy 1802 with a 115 Mercury 4 stroke and I'm having a problem with my battery draining when not in use. I had the boat for 2.5 years before this problem started. The only items drawing power when it sits in my driveway is the carbon monoxide detector, the bow bilge pump in the cuddy and the stern bilge pump. I remove all other devices. I take the drain plug out so water never accumulates to set off the automatic bilges. If i turn off the battery there's no problem, but if I forget to turn it off, the battery is drained enough that after four or five days it won't turn the motor over. Any suggestions? Thanks
UncleWillie
Re: Battery draining
Measure the amount of the drain with an amp meter.
Start pulling fuses until you find the source of the drain.
It could be a bad rectifier in the alternator.
KD4UPL
I would have guess the CO detector would kill the battery in 4 or 5 days. I guess not since you apparently have been doing this for 2.5 years. Like UncleWilli said: measure amps and pull fuses until you find the drain.
Does your boat have a stereo? Did you install one recently? Even off these draw power for the clock and memory.
colbyt
Pure speculation on my part. Any continued use of power when not running will drain an older battery faster than a newer battery as often batteries get weaker before they finally die.
I surely agree with testing things but keep the battery age in mind.
UncleWillie
I would have guessed the CO detector would take over a year to kill it! Same for the stereo.
If it won't last for a few months something is wrong.
Until we get a measurement of the actual drain, we are just making wild guesses.
I would not expect to anything more than 100mA (0.100Amps) <25mA is better.
