Re: Battery dying quickly
Can I assume starter and starter solenoid are good, based on the fact I get 3-4 good start attempts
I would assume that too. I would also assume that the wiring is good.
But it would be well worth while checking all the connections in the wiring, not forgetting the negative ground connection.
It would be worth feeling for any warm connections after several staring attempts ... that would indicate a bad connection.
I would do some voltage checks . Measure the volts directly at the battery terminals while you are cranking and also at the starter motor. If the volts at the battery fall way off below say 10 then the battery is the culprit. If the volts remain fairly good at the battery but fall at the starter motor then there is problem with the wiring.
Are you sure your battery is fully charged. It shows the symptoms of not being so.
Take it off the boat and charge it ... see if that makes any difference.
Have you checked that it is charging on the boat. It should not be dead after several hours running
You have a non regulated rectifier. If it is charging you should see the volts rise to well above 12 volts ... up to about 14.4 when the battery is charged but because it is unregulated then go on rising to 16volts maybe more.
Do you have an adequately large capacity battery?
Is it a starter battery .. not a deep cycle one?
Check the battery volts when it has stood idle with no charging and no load for 12 hours or so.
If it is good and fully charged you should get 12.7 preferably 12.8.
At only half charge you'll get around 12.2 volts
Anything below 11.8 is almost fully discharged.
