nightvision
- Joined
- Mar 7, 2004
- 252
Hi all,<br />I just bought a Schumacher "smart battery charger" 12/8/2 amp for 12 volt batteries. I have a couple questions:<br /><br />a. Before I attach the charger to the boat battery I need to disconnect both the pos and neg cable. Correct?<br /><br />b. If I run the engine blower for 5 minutes or so, can I deep the battery in place and charge it without removing it?<br /><br />c. On the charger there is a function that tells what percentage it's at (ie. 90%, 80%..). Ideally, if the battery will sit for several months at what percent should I let it drop before charging? As I understand, one can charge/maintain the battery any percentage between 100% and 50%. One does not want to wait until the battery is below 50% to hook up the charger. Correct?<br /><br />d. I figure once a month I'll top it off to bring the battery to 100%. Is that the correct procedure?<br /><br />I appreciate any additional comments. Thanks.
