jbmarley30
- Joined
- May 15, 2008
- 19
I took the boat out this weekend and while trying to start it the flywheel spun slow making about a 1/4 of a revolution at a time. It felt way too slow to start the motor. Then it just spun fast enough (out of no where) and started up. (1988 85 hp)
I took it for a spin and shut it down for a few minutes and the same slow cranking occurred when trying to start again. I got it started again by chance. I noticed the battery wasn't charging very good while running. It would stay around 11.7 while trolling and then 12.5 at full throttle. Every time I try to start it the battery alarms goes off and its at about 10.5.
Switched the battery with a newer one (Maxx Marine purchased last year)that was fully charged and got one good start and then the same thing happened as previously mentioned. This problem just started this weekend. Motor would turn over great before.
Checked the cables (that were replaced last year) and they look fine. I'm going to get the batteries tested to see if they're good today. Any other ideas?
Thanks
Thanks
