while working on another issue over the weekend i discovered that my outboard is not charging the battery...i'm only getting 12.4 volts max with the motor running....so i'm obviously operating at a defecit. I checked the rectifier, and it was bad, so i replaced this, but i'm still not getting a proper charge to the battery...i'm guessing that the stator is probably bad also? am I on the right track? (or are there other parts in the charging system that i should be looking at also?)
