Re: Battery Not Maintaining Charge
why doesnt it have an alternator.....technically none of these outboard do, well other than the new verado's. they have stators wich produce AC voltage which feeds down to the rectifier, which inverts the AC voltage to DC voltage(12 volts). if youve ever hooked up your battery backwards, or touched a hot wire to the ground accidently, anything that caused big sparks, could have fried your rectifier.<br /><br />if your rectifier is gone, you need another to charge your battery.<br /><br />radio shack sells a full wave bridge 25 amp rectifier for $3.79... it is FAR superior , faster batt charging, than the origonal, and its cheep, i bought 2. chris1956 told me about it. hooks up in 5 mins. he has been using his for 20 years. check it out
