Ok, I have 3 deep cycle for my boat, one or engine, two for trolling motor 24v. Recently I notice that my trolling motor is not giving enough power to troll. I check the battery and a have a good reading..... Today, I decided to "fix" it but checking to water level. Open the first one for the trolling motor it look fine. Water level is good. Then I open the second one, and damn there are no water in it at all. But the multimeter still giving a good reading of around 13 v , I check it with other multimeter and it also give a good reading..... I added about half gallon of distiller water unit and put it on a charger. Hope that will fix the problem. I can't help but wonder where the hell are all the water. What can cause battery to loose water like this?
Also, how often does the water need to be check?
And last question, how do check if the battery is at it full capacity? Since multi meter only tells the voltage.....
