battery question
mariob
Hi,
I was just wondering if I need a special charger to charge a marine battery.
I have a motomaster charger but I can't remember if it was made to charge deep cycle batteries or not.
also , if your battery goes comepletely dead , how much does that reduce the lifespan of the battery.
someone was telling me that it reduces the lifespan by half. is this true?
Silvertip
Re: battery question
Let's just say that a stone dead battery has been damaged. How much depends on how lucky or unlucky your are. It's really hard to tell - but you will soon find out. The battery may or may not "hold" a charge. But you can find out by charging it and then taking it to any major auto store (NAPA for example) and have them load test it. That is usually done free of charge.
underwurlde
Guessing you have a lead acid battery. Some other types of battery that can be used in the marine world such as NiFe batteries DO need special charging (higher voltage) systems.
Lead Acid batteries can be VERY easily damaged, that is to say their efficency reduced via incorrect charging. Staggeringly, many cheaper commercial battery chargers do NOT correctly charge lead acid batteries and can therefore actually damage them.
The correct method of charging a lead acid battery is to use a 'BOOST' and then a 'FLOAT' setting: A good battery charger will sense the SOC (state of charge) of the battery it is attempting to charge. If it is deemed flat enough then the BOOST mode is used (charger output voltage higher = 14.5V = more current available to charge the battery)
After a period of 'fast' boost charging the battery will become charged and if the boost charge setting is maintained, the battery will become damaged as this high voltage will 'gas' or can 'boil dry' the battery (NOT good)... hence a 'maintain charge' or float charging reigeme is used (charger output voltage = 13.8V = lower current aka 'trickle charging').
Deep cycling lead acid batteries will also damage them, that is to say taking all the energy out of them (letting them go flat) and then charging them all the way back up again - each time this is done the efficency of the battery is ever so slightly reduced - this is an accumualtive effect so over a period of time the battery gradually wears out to a point where it can no longer hold any charge.
Andy
mariob
thanks guys.
I'll post back if I run into problems charging it.
