MASTERBrian
- Joined
- Apr 16, 2011
- 84
I am looking to buy a new battery for my pontoon. It has a 50hp Johnson on it. It's also setup with a spot for a trolling motor. It has a spot for two batteries, so I'm sure I'll go that route eventually and use a large deep cycle for the troller. The question is on the starting/Normal use battery, am I better off actually buying a starting battery or am I also ok if I go with a larger deep cycle battery. This battery will of course start the motor, but run bilge pump for a slide and/or live well, lights, radio, ect. Kind of curious pro/con of either option. My understanding is either will start that small motor without issue, and MY logic tells me a large deep cycle should give me more float time, motor off, lights on and radio going than just the start battery. Is that good logic or bad. Is it worth the extra cost?
