Battery Replacement question
Laker6
I added a Perco switch this winter, and its time to replace the old battery on my 1986 Mariner 75 Hp. Any advice going forward? I do have a new, unused Marine Starting Battery. Should I team that up with a Deep Cycle of the same manufacture?
DickS
I HAVE A 1978 reinell cabin boat and the battery is missing what kind of battery does it take 12volt or 6 volt
Laker6
Probably 12Volt You could start your own thread with that question.
Chris1956
Laker, you do not need to match battery brands. A second marine battery of any brand is fine.
You would need a Deep Cycle, if you run lights, livewells or a real high power stereo, with the engine off. If so, start boat with switch set to starting battery. Run to destination with switch set to both. At destination, set switch to deep cycle.
When time to go home, set switch to starting battery, start motor set switch to both and run home.
Your Merc likely has a small battery charging capacity. Maybe 9 amps? If you do not have those high amp accessories I mention, you may want a second starting battery.
