biglurr54
- Joined
- Feb 14, 2011
- 234
I have a 16ft pontoon that I restored. It is docked at the lake all season. I do not have power at the dock and no reasonable way to get power to the dock. THe pontoon is powered by a 1989 30hp Evinrude. I typically brought along a bluetooth speaker for tunes while floating but this year I installed a bluetooth receiver and a speakers in the pontoon. The wiring has a 10amp fuse so It not a massive amp. Currently I have a cheap walmart lawn mower battery (4 years old now) that i use to start the motor. It has worked great the last 4 years and for $20 you cant go wrong. I am worried about running the speakers off the battery while floating with the engine off.
I have a couple ideas:
1: for $100, I can buy a deep cycle marine battery and just run that one battery and hope that the deep cycle wont get killed by the radio and will stay charged up with the motor running. (We usually arent floating longer than 3 hrs anyways)
2: Add an Isolator switch (80amp Stinger Isolator $16.50) and a small 12v 24ah deep cycle battery. This will isolate the deep cycle battery with the switch off, but allow the stereo to play off the deep cycle and preserve the starting battery, and then reconnect the batteries when the key is turned on.
3: Bring out the bluetooth speakers again. (I would rather use the onboard radio then the bluetooth speaker)
I can also add a solar charger to keep the batteries up while docked. There is no other electrical load on the pontoon.
