Battery Size
hearly
Hi,
I have a Sea Ray 260 with a 350 MAG engine and need to replace two dead batteries and need to know what is the smallest amp size I can safely add.
Cheers,
Hugh
PondTunes
Re: Battery Size
Is there a reason for wanting the smallest amperage you can get by with?
A good battery is well worth it's price if it's got the juice to crank your engine every time. Scrimping on a battery to save a few bucks could leave you stranded or you could end up buying another one if a bargain battery dies on you.
hearly
Re: Battery Size
I just want to make sure I don't buy to big and take up excess space and weight or to small and not have enough juice.
Would 2 x 75AMPs be OK?
bruceb58
Re: Battery Size
Assuming you don't have a lot of electronics running with the engine off or a fridge, I would just buy two 27 series batteries. The weight difference between a 27 and a 24 is not enough to worry about.
