Battery Smoking! ???
Mnemonic
I got all the controls done today, and i tried turning over the motor. Of course my luck it wouldnt start after spending so much on the new controls for it, but i noticed something strange... The barrety started smoking while it was turning over on the + side terminal.<br /><br />Being that the battery is near the gas tank I immidiatly called it a day. Any idea on what this could be?
Paul Moir
Re: Battery Smoking! ???
Most likely a bad connection at the positive battery cable connector. Clean it and the post of the battery really well.<br />While you're at it, clean up the other connections.
Mnemonic
Any suggestions on what to use to clean it?
salty87
wire brush and some coke will do the trick on the battery post, coke eats that stuff up<br /><br />sandpaper on the ends of the cables will clean them up
LubeDude
If cleaning things up doesnt do it, (Thats the normal cause), You have an internal short in your battery, new or old, its time for a new one.
RatFish
Careful with those battery shorts. Had a cell blow on me one time!
Jdeagro
iboats.com Partner
myoutboards;<br />Just trying to help!
