Re: Battery switch help What is the correct use???
Depends on your set up. I have a starting battey on pos.1 to start the motor. Pos.2 is a deepcycle for when I fish with the motor off and use my lights, fishfinder, etc. If your switch is "make before break", you can switch from 1, both , or 2. DO NOT TURN OFF WITH MOTOR RUNNING! I also have an isolator so the weaker battery doesn't draw from the stronger battery and rundown. The weaker battery will charge first then the stronger battery.
