duke3478
- Joined
- Jul 20, 2009
- 58
Installed a Blue Sea 9001e today, per instructions. Batt 1 pos cable to terminal one, batt 2 pos cable to terminal two, batt 1 neg to batt 2 neg terminal, to engine ground. Engine positive to common terminal.
like this:
Here's where it gets weird. With the switch in the 'off' position, I expected to have no electrical power at all, but my tilt motor clicks (not quite running) my spotlight plugged into cig lighter outlet comes on dimly, and blower/bilge run, but very slowly. Everything in the 1 and 2 positions is normal, tilt runs, starter turns, light is bright, etc.
Basically I seem to have a very low voltage coming through, with the switch off. Have I done something wrong, or could the switch be allowing a trickle of juice to come through? Is this a malfunction or something engineered in?
Thanks in advance, I always get the best help on the forum. You guys always steer me right.
like this:
