Re: Battery Tester
I'm with the "what type of battery" crowd. Assuming you are speaking of auto type batteries any of the above suggestions will work. If you are speaking of Li ion, NiCad, alkaline, or smaller lead acid batteries more information is needed. Also, what type of testing do you want. Not all batteries can be tested the same way. For example, my occupation uses a large number of rechargeable batteries (Li Ion, NiCad, and Lead Acid) we spent about $2000 on a battery tester and then many hours setting up the tests (honestly we should have opted for a better, more expensive model as this one doesn't work 100%). For home use this would obviously be overkill but we needed to know many factors to properly gauge when to replace batteries.
