mniact
- Joined
- Sep 11, 2008
- 12
I am installing a battery switch, on one of the small red power wires there is a capacitor/resistor-type thing at the end of it and a rectangle brass plate screwed to the capacitor and the other end of the plate directly to the battery post.
The problem is that when I tried to connect this brass plate to the back of the battery switch the brass plate is too short and the capacitor is situated behind the battery switch and I cannot mount the switch to the side wall.
My main question is ? is the brass plate anything ?special? or just a way to connect the capacitor to the battery. Could I just run a wire in place of the brass plate?
Also, the case of the capacitor/resistor thing is metal, if I have this hanging off the battery switch, which is mounted to the side wall of a pontoon boat, can it touch the metal wall of the pontoon boat?
Thanks for any help!
