Bayliner 175 merceriser 3.0 no fuel to carburetor
favalos08
Boat turns over but doesn't start, checked carb and when throttling there is no fuel going into the carb. Fuel pump was cleaned today & fuel filter in fuel pump was replaced, fuel tank was syphoned and fresh gas with stabil was put in.
dubs283
could be stuck needle/seat
have you verified the fuel pump operation?
welcome aboard
since you cleaned the fuel system, I assume that you had bad fuel or the boat sat for a long time.
check to see if the anti siphon valve is stuck, or the pickup strainer is plugged. if the strainer is plugged, remove it. you should be running a water separating filter anyway.
Aside from what has all ready been mentioned, did you remove and check the inline filter on the carb inlet?
