Re: Bayliner 2455 winch size?
I'd say any 1500 lb or higher should do fine. Remember that you are not moving all of the weight of the boat, especially if you have a roller trailer. One with 2 gear ratios may a consideration if you have to winch it up a ways onto the trailer.
But as a rule of thumb for me, I use the biggest one I can get. I have an electric one that pulls 3000 lbs for a boat that weights about 3000 lbs. I'm just lazy tho.
You can't go too big but you certainly can go too small.
Consider the 5000lb boat.
Assume flat pull friction at 10% = 500lbs
A 20 Degree ramp will add another 35% pulling uphill. = 1750lbs
Total = 500 + 1750 = 2250lbs.
Winch ratings are quoted for a nearly empty spool. (Gotta love the Marketing guys!)
The winch with a full spool is down to about half the empty spool rating.
1500lb Winch with a full spool = 750 lb pull.
5000lb Winch with a full spool = 2500 lb pull.
The 5000lb winch with a full spool has a 2500lb capacity pulling a 2250lb load.
The 1500lb winch gave up right after the boat came out of the water!
Go BIG and GO
Two Speed!
They are not that much more expensive!
You will never regret overbuying!
