Bayliner 2502 trophy 1995.
Hi
I want to buy a new engine. And just run with single engine. Does enybody know if i need a xxl size engine on my boat. Ang witch size i should get. Im Thinking of a 250 hk
JimS123
What size engine do you have now? Single? twins? What is the boat rated for? What is your transom height? What's a witch engine? What's an hk?
Need better info...
dingbat
A single 250 outboard would be ok
You need a 25” shaft motor
Chris1956
If you want a sterndrive, I would recommend a big block motor. Those have about 330HP.
Hi
I have twin 135 mercury salt water 2003. I messured at the back off the boat. And it was 78,5 cm. So i think its xxl. I dont know what the boat can handle?
dingbat
Rate to 400 HP
QBhoy
Is that boat honestly rated to 400hp ? I’ve only ever seen them with inboard or less than 200hp 2 strokes.
