Bayliner contessa 28 feet Volvo penta V8 5.7 L 1984
Riadbravo
Hi every one ,
need informations ( see pictures bellow ) name and type of propellers Engines Volvo penta 350 HP ( AQ 225 D) ?????????
QBhoy
I can’t quite be sure, but memory is telling me if it’s an AQ225...they may be 5.0l engine. Won’t be anything like 350hp. Think the 5.0 was 225hp and there is certainly an AQ271 5.7 I’m very familiar with too. About 270hp or 260 at prop perhaps. Can’t be sure. Your outdrives I think are 280 SP’s. Have a look online to check though.
Riadbravo
Thanks for your replay
Ayuh,.... Welcome Aboard,...... If you pull the props off, 'n clean 'em up, you should be able to find numbers on 'em, that'll tell ya the pitch of 'em,....
Sometimes it's stamped into the barrel, other times cast into the hub, under the nut,....
