78ImperialT
- Joined
- Jul 25, 2009
- 203
alright...I NEED HELP!
i cleaned all the connections and charged the batttery and viola...it works! so the starter is good to go.
so heres my problem... i pulled the carberator off and and cleaned it ...the right way. checked all the fuel lines and checked the fuel pump. also i removed the intake manifold and cleaned it out. all the plugs are good and im ready to go...right??? WRONG it wont start.
im not sure if i put the wires back right on the ignition switch and coil. on the ignition switch are three connections...B I S. also three wires...red white/red stripe purple. which wire goes with which connector?
on the coil are two connections + 15 - 1 and two wires purple and one with two wires purple and white. which wire goes on which connector?
i thought i had it right but i figured out that there is no fire at the distributor. it could be a bad coil or a bad cable but i dont know how to test it and im not sure i have the wires in the right spot.
thanks in advance.
ps... theres more at the end of this thread
http://forums.iboats.com/showthread.php?t=340686&page=3
thanks in advance.
