97 Baliner, outboard, salt water boat...Winterization
Storing in a heated 10 degree celcius shop
-Been running stableizer in fuel last couple of times out to get it through engine
-fresh water flush engine/inside & outside
-fog engine
-clean/rust check engine
-drain/change lower unit gear oil
-remove prop/bag shaft/tape all outlets on leg
-lube steering/throttle. rust check
-battery out, in house/check, charge 2 month interval
-clean boat hull/interior
-jack trailer, weight off wheels, rust check as reqd.
-store all boat gear in boat and cover..
Anything i missed???
thanks guys
-fog engine
thanks guys
