Bayliner speedometer
The Force power
I was searching for some answers regarding the speedometer & their readings.
I can't find back the old post where Scott (I believe) posted **PSI = ** MPH
I'm trying to figure out how to calibrate / verify the needle's position
mr 88
GPS on cell is the best way to check how far off your dash unit is. Do not think you can calibrate them.
The Force power
Yeah...I've read that, I needed the old post;so I can bench-test the gauge.
I found the old post;
test the gauge using air pressure: 5.6 PSI = 20 MPH; 12.6 PSI = 30 MPH; 22.4 PSI = 40 MPH; and 35 PSI = 50 MPH.
