Bayliner with force 125 outboard motor
Well I started by checking the water pump before the weekend coming up and there was no water coming outta the exaust holes. So I went to change the lower unit oil and took out the clucth pin to drain it. So I took the l/u off and changed the water propeller and then reassemblied. I lokk in the Oweners Manual and it said NEVER REMOVE THIS PIN, yeah should have read the manual first I know, so know its stock in forward and will not go outta gear I think so does Anybody have any ideas on what to do now? Please hope I dnt have to take that l/u apart again, but it has to be done so be it. So if anybody has a trick or some good plan please let me know Thanks.
NYBo
Re: Bayliner with force 125 outboard motor
Welcome to iboats!:cool:
You've made a fairly common Force mistake. Here is a possible solution.
