Bearing Buddy.
lmannyr
I had the caps on the hubs and the seal surface rusted out within 8 months. Now, I'm planning to install bearing buddies with the hope the positive pressure theory will help keep the water out.
So...Wal-mart bearing buddies just as good as the REAL "Bearing Buddies"?
Quality the same?
Barnacle_Bill
Re: Bearing Buddy.
Best I remember they will throw grease so you need a pair of bonnets for them.
reelfishin
Re: Bearing Buddy.
I bought a set at Walmart last year, stainless steel, Bearing Buddy brand and they've been fine, but I see now that they dropped all the normal name brands in favor of everything branded Attwood. They're no longer cheaper so I haven't bought much there since.
I did buy a set of Red Eye bearing caps which seem to work good, but their made of some sort of pot metal, so I doubt they'll last very long if I get near saltwater.
Being in a saltwater area, I do tend to paint the bearing buddy and hub once installed, it helps prevent that pitted, corroded look that's so common.
I mask off the face and paint the whole hub assembly real well, and grease the hub flange and studs. Otherwise none of it lasts more than a year in saltwater.
