When I pull the prop I see the bearing cage. I see oil leaking from the outside of the bearing cage.
To pull it off do I use the threaded holes there up close to the prop with a puller, or do I have to undo the two bolts down in the lower unit also.
I want to free it to replace the bearing cage o-ring.
thanks
thanks
