bearing carrier nut 200 EFI...
Trying to replace the prop seals in my 200 EFI and the 4 inch nut that holds the bearing carrier in is froze solid. Got the special tool to use on it, applied heat, stood on the breaker bar, did not move a hair. Someone told me that the only thing I could do is drill the nut on one place and break it out then reinstall with a new nut. Has anyone done this before? will this work to allow me access to pull the carriage? Desperate for any help....thanks
Faztbullet
Re: bearing carrier nut 200 EFI...
Did you bend the tab up on tab locking washer as it locks nut in place???
yes I did, I also found an old thread on this forum that tells how to drill it out. There is also a great you tube video that shows the proceedure....I could still use any pointers someone may have...
