ledgefinder
Ensign
- Joined
- May 2, 2002
- 916
I have a 1975 OMC 115hp V4. The outer propshaft seal looked iffy, so I thought I'd replace it - now I suspect I've ruined the LU. I can't get the bearing carrier out. I removed the 4 bolts, put the puller on it - no dice. Tried heating it until I took some of the paint off - didn't budge. Tried banging on the puller with a hammer until I stripped one of the hole's threads (BTW, next size tap - 3/8 works real well to rethread). <br /><br />Just wondering whether I should give up yet. Do they "always come out" if you keep at it, or is it common to have some that are just stuck. The case has seen some salt, but isn't corroded. There is a ding (flat spot) on the side.<br /><br />Thanks!
