skynyrdcat
- Joined
- Mar 11, 2007
- 157
1988 V-4 (110 HP)
Anyone got a spec sheet for bearing diameters?
I'm rebuilding (and I'm the perfectionist type.) With the rebuild (plus preventative work) I'm nearing the $1000 mark for parts and block work alone. As far as wrist pin bearings, rod bearings and the upper crank bearing, I'd like to know if their is a tolerance for the individual pin diameters. If so, I may reuse parts that are well within tolerance.
crank case sealing rings... I'd like to know the specs on those too.
Thanks in advance!
Thanks in advance!
