petrolhead
- Joined
- Oct 16, 2003
- 614
Hi guys, it's been a while since I posted here, too busy building my boat but now I need to ask a question about my Johnson 18 FD-12.<br />Some time ago when I bought the engine I had it checked out by the local outboard specialists, they told me that it needed all new ignition components, HT leads, carb kit, etc..., they also told me that the upper shaft bearing was worn and needed replacement.<br />I've got all the parts I need including a new bearing, but now I've started to strip the engine I'm beginning to wonder if there's actually anything/much wrong with the old bearing.<br />When I grasp the flywheel and rock it side to side and back to front, I do feel a very slight movement, like a couple of thousandths of an inch at the flywheel rim, which must translate to less than one thousandth at the bearing. Is this too much and should I replace it?<br />I have reason to believe that this outboard place is not being entirely honest with me, several times I've been there for advice and parts, to be told that simple things like cables and connectors are unavailable, only to find that they are! <br />I get the impression that they are trying to get me to pay out for expensive and unneccessary work, or are hoping I'll just give up and they can sell me a new engine!
