Bearing size compared to axel capacity
External Combustion
I have noticed several questions about the load capacity of unknown axles.
This has been gleaned from a number of catalogs.
bearing size bearing numbers axle capacity seal number
inner outer Inner outer
1" 1" L44643 L44643 1500lbs 34823
1 1/16 1 1/16 L44649 L44649 2000 lbs 10-9
1 3/8 1 1/16 L68149 L44649 3500lbs 58846
1 3/4 1 1/4 25580 L67048 5200/6000lbs 10-10
1 1/2 0.938 2788 1779 5200lbs 29031
1 3/4 1 1/4 25580 14125A 5200/7000lbs 10-1/42385
1 3/4 1 1/4 25580 15123 7000 lbs 10-1
1 3/4 1 1/4 25580 02475 8000 lbs 10-48
This should help identify axle capacity. Remember that the capacity mounted on the trailer is the lowest capacity of the axle, or the tires, or the springs or the hangers.
I am having difficulties posting this with the proper spacing on the headers and data. Will one of the moderators help out a computer novice?
