Bearing size specifications needed
Nijkampr
Hello all,
I have a Shoreland trailer similar to the attached picture and I wanted to add some brakes.
To save myself some guess work, I was hoping someone here would be able to let me know what the bearing size for this trailer would be.
Thanks,
Rob
Bob_VT
Re: Bearing size specifications needed
If you are going to service the wheel bearings.......... just pull one off and head to the parts store with it. It is a total unknown if you have original axles or what size bearings were used. Bringing one to a parts store will get you the proper size and drag along the wheel for the proper seal size too.
robert graham
If you have a Northern Tool store in your area, they carry just about anything for trailers and may well help you with your needs.....
MH Hawker
Yes your going to have to get your hands dirty. :D
gm280
I suspected as much.
Thanks to everyone for the feedback!
Not knowing what your axles are like, you may need to carry both the inter and outer bearings with you. Some axles are stepped meaning the inter bearing is of larger size then the outer bearing. And also carry the seal as well to get the right size too. Good luck.
