bearings help?
DareDog
have mercuriser and gimbel bearings will not come out even with slide hammer. any ideas on what to do?
mkast
Re: bearings help?
The bearing can be hard to remove.
Try a different (bigger) slide hammer.
littlebookworm
Re: bearings help?
There is a different type of puller which is basically two flat steel plates and a threaded rod. Both plates have a hole through their centesr. The smaller one is slid behind the bearing. The larger one sits outside the gimbal housing. The threaded rod goes between them. Tightening the rod pull the inner plate forward, pulling the bearing out. Auto mechanics have this type of bearing puller. Or, as was suggested, get a bigger slide hammer, You can usually rent or borrow a heavy-duty slide hammer from some auto parts supply stores. Good luck. Hy
cr2k
Re: bearings help?
How long has it been in there? Which drive? How much corrosion in the housing?
DareDog
Re: bearings help?
alpha one, not sure, bought it used. 93 bayliner. im assuming since 93.
DareDog
Re: bearings help?
dose advance auto have big slide hammers to rent?
do i need a tool to install the new bearing?
Re: bearings help?
Ayuh,... Ya need Atleast a 10lb. slide hammer....
A bearing driving tool can be fashioned outa a piece of PVC pipe...
Just be sure to be poundin' on only the outer most race/ carrier...
DareDog
Re: bearings help?
ok thanks for all the help. going to call around to few places tomorrow to see if they can do it and when they can.
