Beep Code in my Johnson/Javelin Boat
z71crazyman
Is there anyone out there that can help me find where to look up a beep code on my 1989 Javelin with a Johnson 110 on it? I have looked all thru the my books and documents and cannot find anything good on the internet. Any help that you can provide will be greatly appreciated.
rodbolt
Re: Beep Code in my Johnson/Javelin Boat
1/2 second tone every 1/2 second is no oil in the oil pump, a 1/2 second tone every 20-40 seconds is low oil tank level. a steady tone is overheat<br />the horn should give a 1/2 second tone once when the key is turned on. if it does not it usually means the horn failed.
z71crazyman
Rodbolt that really helps me out. Is there a place that you know of where I can snag this documentation? I will add oil tonight and see but it looks as if it is half full as it is. Thanks for the help and if there is any different facts or opinions that would be helpful as well.
