rick3452
- Joined
- Oct 26, 2010
- 282
I've ruled out a list of things that may be causing my "high speed overheat" (thanks to the help from here)
im on the verge of installing a Buck Algonquin Though Hull Water Pic k up on my 2000 Mercruiser 5.0 with a Bravo 3. 1800 hours. I have done the following.
replaced Manifolds and Elbows both sides. (They had 1500 hrs on them)
Replaced impeller with OEM Mercruiser complete kit. (It was completely intact)
Replaced aluminum exhaust tubes (both)
Pulled off covers on Heat Exchanger fairly new and completely clear.
Power steering oil cooler clear
Thermostat opens right at 160 and stays there till I run the boat at 3800 RPM for several mins.
Then it goes to about 172/175. Throttle back and within a min or two right back to 160
Verified with IR Laser at hose going from outlet of thermostat housing to Heat Exchanger to be 172 when hot.
I've been reading a lot about "Bravo-it is" If I do choose the Through Hull route is there any negatives to using a Tee to connect the existing hose to work in conjunction with the new Through Hull?
Is there anything else that I am missing?
thanks so much!
Rick
thanks so much!
Rick
