Bell housing hinge pin tourque?
aarons 470
Hi all, I’m seeimg mixed info on proper tourque for housing hinge pins on MC-1 drive. What are you guys doing on these? And medium or heavy loctite?
Ayuh,..... On the MC-1, the pins are pushed in, 'n the aluminum nail inserted to lock 'em in place,......
On the later drives, the Alphas, I just run 'em in to "Good, 'n Tight",..... No loc-tite at all,....
I donno whether they changed with the R, or the MR, or the Alpha 1s,.....
achris
More fish than mountain goat
Early MC1 had the nails. About 1975 they changed to the screw-in jobbies that we still see today... 60ft-lb, and if you want to use any Loctite, make it the low strength one, 222 (purple).
Chris........
Bt Doctur
Dont use the RED, no need to go that strong and have to use HIGH heat to remove it
