Re: Bell Housing Pin Removal
i'm w/fm.
your at the point that yer either gonna win or lose as your down to some kinda forcible extraction.
myself. i think i'd go with the drill bit down the nail. trying to keep in the center of the nail. maybe start with the existing dia. of the nail, then if ya drift off, perhaps go to the larger size nail hole and ream the whole old nail out and size up to the new larger nail.
i'm a little ambivalent about the force the hinge pin and shear the nail. shear strength may be pretty solid. maybe go w/ drill bit, then after some of the nail is gone (the part of the nail that's inside the hinge pin will need to be gone), then try and drift the hinge pin out (fm's idea), after the nail has lost some shear strength due to it being drilled out.
what ever ya do, don't break off a drill bit in it... that'd leave ya sol for sure if the drill bit couldn't be extracted.
if drilling, staying on center of the nail will be of most importance i'd think. probably hard to do to. will be hard to tell when your in the cast alum of the gimble ring or the solid alum. of the nail.
bummer about your woes, and good luck/skill..
