bell housing
leeann4
alpha one: changing all bellows and gimble bearing this weekend does the bell housing have to come apart to install bellows? any other tricks and or things i should look for and do while im in the middle of replaceing.<br />thanks
Haut Medoc
Re: bell housing
No, you do not have to remove it, but it is nearly impossible if you don't...<br />Do yourself a favor & remove it to do the job....<br />You should replace the shift cable at this time, as their service life is about the same length of time.....<br />If you 'search', Don S. posted a link to Merc. manual #6, that is what you need for the job....<br />It ain't that hard, just time consuming....JK ;) :)
Re: bell housing
And Awlfully Hard on the Knuckles.................. ;)
tommays
Re: bell housing
You really need the full box of bandaids :eek: <br />
<br /><br /> http://www.boatfix.com/merc/Servmanl/6/6A4R3.PDF <br /><br />And i would print a copy of the service manual and study it a while :) <br /><br />Its is a DIY project BUT you really have to take your time as any mistakes or short cuts will result in doing it twice :eek: <br /><br />tommays
lilmandavis
Re: bell housing
shouldnt the extra rib go down. so that it can stretch more whaen its trimmed up?
Don S
Re: bell housing
shouldnt the extra rib go down. so that it can stretch more whaen its trimmed up?<br />
Merc and the older Volvo 290 style are marked as to how they are installed.<br />OMC and the Newer Volvo SX/DP-S style use the same kind, and are not marked. Neither Volvo nor OMC ever stated there was a particular way they went on. So this extra rib thing is nothing I ever heard about. Besides, it's a spiral and I think there are 7 ribs no matter where you count them.
natwales
Re: bell housing
I just re-sealed my transom a few weeks ago on an alpha 1. I did the shift cable, shift shaft, u joint bellows, exhaust bellows, water hose - just about anything that would ever need to be replaced was. I had never done this before and It took me two long days. <br /><br />Here are a a few tips that I came away with.<br /><br />- when putting on the U-Joint bellows, remove the stainless steel wire in the bellows so it will be easier manage. Once the bellows are glued in place, feed the stainless wire back into it's track.<br /><br />- bring a propane heat and a very long breaker bar for those hinge pins. Took me several hours to free up. It needed lots of heat and torque.<br /><br />- use the exhaust tube and not the exhaust bellows if it's an option. It'll be much easier to put on and will save you needing the bellows expander tool. You also will not have to remove your shift shaft.<br /><br />-buy all the special tools you will need. Get them on ebay and re-list them when you are done.<br /><br />- bring a portable hot water pot to boil the ends of the hoses to make it easier to get over the nipple.<br /><br />- Don't force any bolts that won't come out easily. I managed to sheer off the bolt for the trim sender and it was a real hassle. Use lots of heat and penetrating oil and go slow.<br /><br />- I found that a socket wrech with and extention and a swivel head was essential.<br /><br />- Pay carful attention to the order in which you do things and always think a few steps ahead. This makes it much easier to get at hose clamps, etc. One mistake I made was that I did my shift shaft before my exhaust bellows and the whole thing had to be removed.
natwales
Re: bell housing
one more thing. One those hingepins- when you try to free up the port side, the whole bellhosing assembly will want to pull up as you try loosen the bolt. If it's possible leave the outdrive on for this step so you can put a foot on it for leverage. I already had mine off and had to use some line to hold the bellhousing down.
