I just replaced my u-joints, u-joint bellow, and gimbal bearing. I took the boat out (5.7 OMC Cobra) for about 45 min a couple days after doing all this. I started the boat in the driveway today and could hear a little more noise than normal coming from the gimbal area. I checked the gear lube (at the bottom plug it was clean, at the middle plug it was clean, through the dipstick hole it was milky white and foamy). So I pulled the drive off again, and of course I have a u-joint bellow that is full of water.<br /><br />I realize I will need to replace the u-joints and gimbal bearing again. Is there a seal or something I need to replace where the yoke goes into the drive?<br /><br />How can I determine if I was getting water into the bellow from one of the bellow connections or because the drive was not sealed to the bell housing?<br /><br />I do have a manual and followed it closley but didn't get something quite right... I also want to make sure that there is NOT suppose to be a hose clamp of the front (furthest from the gimbal bearing) side of the u-joint bellow (that is, the u-joint bellow only uses one hose clamp, closest to the gimbal bearing)?
