Bellows Replacement
Bob1958
My Alpha 3.0 is 12 years old, and although the bellows all look fine I'm being told they should be replaced. How big of a job is this and how much should I expect to pay to have this work done?
BEARMAX
Re: Bellows Replacement
NOT THAT BAD U DO HALFTA REMOVE THE STRNDRIVE ONLY BECOSE OF THE SHIFTER CABLE BUT IF U ONLY DO THE EXHAST ITS NOT THAT BAD U DO NEED TO KNOW WHAT UR DOING OR U WILL BREAK THE SHIFTER LINKAGE .I WOULD INSPECT THEM IF THERE STILL PLYIBLE AND NOT HARD ID LEAVE THEM ALONE..sorry for the caps
meesh
If they truly are 12 years old, replace them. It's not that bad of a job as long as you have some mechanical skills and a manual.
Bob1958
I do have a manual and I have taken the lower unit off before. The manual does speak of some special tools and glues you need for this job which leads me to believe that maybe a professional should do it, which is why I'm trying to determine how big of a job this is. I can call a dealer and get a price but I suspect it will be steep.
zbnutcase
Whenever I do a bellows job, it includes gimbal bearing, u-joints and new shift cable and averages bout a grand, give or take.
