Bellows Sleeve Installation
Status
Not open for further replies.
300sflyer
Hi guys,
Im working on a 94 Alpha 1 gen 2.
Im just about finished installing all new bellows, gimble bearing, u-joints, shift cable, and I am stuck on one thing...
Im trying to install the new u-joint bellows sleeve, and the manual refers to an special installation tool to do this. I don't have one... Is there a way to install it without one?
Thanks
Don S
Re: Bellows Sleeve Installation
Yea, just get a can of Mercury OB power tuner. Spray it on the ring and the bellows edge where the ring will go.
You can push it on by hand (a bit of a need 4 hands at a time thing) or you can make a plywood disc the same OD as the ring OD to help push all places at the same time. If it slips out, push it back in and hold for 10 to 30 seconds for the power tune to evaporate. Then, it's in and won't come out near as easily.
PS. OD stands for Outside Diameter
300sflyer
Don,
Tried to do a search for the ob power cleaner, but could not find anything. Is this stuff just like carb cleaner, or sone other generic product?
Thanks,
Don S
POWER TUNER, not cleaner. Check with your local Merc dealer, they keep it on the shelves.
Zackman
It's Mercuy's Power Tune. Should be able to get it your local Mercury Parts Store. It different than carb cleaner or engine degreaser you would get at an auto parts store.​
Looks like this​
bpmcl00
300 was this your fist time doing a transom repair kit?
also did you use the gimbal bearing puller to get it out. or any tool to get the new one in?
if this was your first time, how would you rate this experience for first timers?
curious because im about to do this to my boat.
THanks and good luck
Don S
PLEASE, Don't either of you take this wrong, but we have a guy that can't get his put together because he doesn't have the proper tools. It's impossible to know if what he has already done has been done correctly or not. But you want feedback on his experience? Obviously, it can't be that good, as he can't get it back together.
300sflyer
If the truth be known, this is the second time I have done this. The first time was a couple of years ago, however it was a bit easier as it was a 1987 first generation Alpha 1.
To make a long story short, this past fall I bought a used boat knowing it had a cracked engine block, from improper winterization by the previous owner. The price was VERY right, and I knew that with any luck and a lot of patience, I could make it run again.
I managed to find a used Mercruiser engine in very good condition [same size and year] and swapped the old one out for the new one. While the engine was out, I pounded out the old gimble bearing from the inside using a large wooden dowl. The new one went back in a similar way, only I was very carful not to touch the inner race and keep the bearing square all the way in. After an engine alignment and putting the drive back on, I did fire up the replacement engine for about half an hour, and all is well.:D
While the engine installation itself was pretty straight forward, it was a lot of work. I had to rig up a chain falls from the ceiling in my shop and use it to do the lifting. A standard automotive engine lift will not lift the engine high enough.
As far as the bellows installation kit, I'm sure someone else with all the right tools, and more experience than I could have done it in much less time, but I did take my time and make sure everything was correct. ;) I must say after all of this work, I now have a new respect for marine mechanics and all of their knowledge.;)
I would say that if you are fairly mechanically inclined, and have a good set of tools, [sockets, wrenches, screwdrivers ect..] you should be able to get through it. If you are working on this in your driveway out in the cold, I would say forget it... Pay someone. You need a warm shop with good lighting to do this, especially if you have never done it before.
Hope that helps.
300sflyer
Success!!:D
I could not locate any power tune nearby, so I used some soapy water which seemed to do the trick. I also put a bit of bellows adhesive on the joint to help hold the bellows in place while the sleeve is being forced into position.
Here is an installation tool I made up, expanding on Dons idea a bit. Primitive, but effective.;)
Now if the 3 feet of ice on the lake would just melt, :( I could go boating this weekend... LOL!!
Robhoov
What holds the bellows to the gimbal housing? The clamp holds the transom end and it appears that the sleeve fits inside the bellows but what is holding the bellows water tight ? Does addhesive hold it to the sleeve. I am in the middle of changing it. Cant get the hinge pins out thought I would try to do it without. Thanks for any info.
Don S
Best to start a new thread with your questions, not at the end of someone elses old thread. Your post will be lost after a couple of replies.
Status
